Regarding Observation 4298990 …
This one can be decoded by @EA4GPZ gnu-radio decoder.
→ Packet from 9k6 FSK downlink
Container:
ax25_header = Container:
addresses = ListContainer:
Container:
callsign = u’3B8MRC’ (total 6)
ssid = Container:
ch = False
ssid = 0
extension = False
Container:
callsign = u’3B8MIR’ (total 6)
ssid = Container:
ch = False
ssid = 0
extension = True
control = 0x03
pid = 0xF0
telemetry = Container:
header = b’\x00\x10nn\x18\x89’ (total 6)
beacon = Container:
battery_current_lsbs_3v3 = 6
battery_current_vbat = 278.592383
battery_voltage_3v3 = 3.3367139999999997
battery_voltage_5v = 5.038035
battery_voltage_vbat = 7.671029
battery_temp = 27.424399999999995
solar_current = 1.955034214
solar_voltage = ListContainer:
0.009971
0.019942
0.009971
0.009971
0.0
0.0
0.0
0.0
0.0
eps_bus_voltage_vbat = 7.649255999999999
eps_bus_voltage_3v3 = 3.3322870499999997
eps_bus_voltage_5v = 5.04398858
eps_bus_voltage_12v = 11.965395832
eps_bus_current_vbat = 20.7
eps_bus_current_3v3 = 204.231252615
eps_bus_current_5v = 104.73397569999999
eps_bus_current_12v = 6.21
adcs_raw_gyro = ListContainer:
333.84161339999997
-7.479118799999999
-8.3436966
adcs_mtq_dir_duty = ListContainer:
0
0
0
0
0
0
adcs_status = 1792
adcs_bus_voltage_5v = 5.005921709000001
adcs_bus_voltage_3v3 = 3.3343024000000003
adcs_bus_voltage_1v5 = 1.513052692
adcs_bus_current_5v = 0.10813900248
adcs_bus_current_3v3 = 0.0672084
adcs_bus_current_1v5 = 0.07422173076923069
adcs_board_temp = 17.697780000000044
adcs_adc_ref = 32773
adcs_sensor_current = 0.013404814794720932
adcs_mtq_current = 0.00048698262965425545
adcs_array_temp = ListContainer:
-15.464459999999955
-15.327299999999953
-15.174899999999953
-13.833779999999953
-10.709579999999955
-16.325519999999955
adcs_css_raw = ListContainer:
3.1127450980392153
3.237254901960784
3.195751633986928
3.3202614379084965
3.195751633986928
3.27875816993464
fss_active = ListContainer:
0
0
0
0
0
0
css_active_selected = ListContainer:
0
0
0
0
0
0
adcs_sun_processed = ListContainer:
-3.0517578125e-05
-3.0517578125e-05
-3.0517578125e-05
reserved = ListContainer:
4542
29235
34665
41405
adcs_detumble_counter = 0
adcs_mode = (enum) standby 0
adcs_state = (enum) sun 1
reservedA = 641
reservedB = 8
reservedC = 56
reservedD = 7
reservedE = 2
cmc_rx_lock = True
cmc_rx_frame_count = 9
cmc_rx_packet_count = 9
cmc_rx_dropped_error_count = 0
cmc_rx_crc_error_count = 11462
cmc_rx_overrun_error_count = 0
cmc_rx_protocol_error_count = 0
cmc_smps_temperature = 22
cmc_pa_temperature = 22
ax25_mux_channel_enable = ListContainer:
True
False
False
digipeater_enable = False
pacsat_broadcast_enable = True
pacsat_broadcast_in_progress = False
param_valid_flags = ListContainer:
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
True
checksum = 49299
Could not parse telemetry beacon Error in path (parsing) → ax25_header → addresses → callsign
stream read less than specified amount, expected 6, found 0
To re-prodece decoding, use theese commands:
ffmpeg -i satnogs_4298990_2021-06-22T14-53-46.ogg -bitexact -acodec pcm_s16le -ar 48000 -ac 1 satnogs_4298990_2021-06-22T14-53-46.wav
gr_satellites MIR-SAT1 --wavfile satnogs_4298990_2021-06-22T14-53-46.wav --samp_rate 48000
