Regarding Observation 4284151 …
Although the waterfall shows a clear signal, the audio is silent (only normal background noise). Is this GOOD or BAD? I personally would rate it as BAD.
As the signal has a fairly apparent curve to it, it indicates it was not from the target satellite and is most likely local noise of some kind.
