Observation 413236: METEOR-M 2 (40069)
Regarding Observation 413236
Hi, I have seen other ground station observations for the M2 and mine looks a little different. On mine it looks like the signal is stretched in the waterfall image where on others I see the M2 signal in the center. How can I fix that, I havent seen my GS decode the M2 and know my setup can get a good signal using other methods.
SatNOGS does not have an LRPT demodulator yet, to get images and a waterfall image with a bandwidth large enough to contain the full signal you have to add a LRPT demodulator and processor manually. The stations you are referring to have done that.
There are some instructions on how to do it here:
I am getting stuck when executing the grcc:
grcc -d /usr/bin/ lrpt_demod.grc
linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
Validation failed:
Block - audio_gain - Variable(variable):
Param - Value(value):
Value “satnogs.fm_demod_settings[rx_sdr_device][‘audio_gain’]” cannot be evaluated:
‘module’ object has no attribute ‘fm_demod_settings’
Error during file compilation.
UPDATE: I got everything working. This would of been a nice pass if APT didnt come ruin the party.
https://network.satnogs.org/observations/479769/
Was it an issue with the current Meteor decoding flowgraph, or something else?
I did need to use a different flowgraph that was provided from someone else in this post and I had some permission issues here and there.
