Observation 3883509: FUNCUBE-1 (39444)
Regarding Observation 3883509
Seems like a strong signal. But no data.
What can i do to improve?
73 Göran
I seem to remember that there is no appropriate demodulator and/or decoder for the funcube satellites. Someone with more knowledge will correct me if I’m wrong, though.
–Roy
Correct. No-one has implemented the Funcube telemetry framing.
The audio from the observation can be replayed into the Funcube Telemetry Dashboard software and decoded however.
Thanks for info. I learn something every day.
People do add their own post-observation scripts. Like this one:
https://network.satnogs.org/observations/3900914/
Perhaps @PE0SAT will share the method with us? 73s C
Off course @drchrisbridges
Currently there is some development being done by SA2KNG that opens up the ability to integrate other decoding solutions. In this case we are using gr-satellites and the satnogs-flowgraphs development release with some additional manual configuration.
Basically we are using the gr-satnogs IQ out, after doppler correction and feed that to another decoder.
You need to be familiar with (*)nix, shell scripts, python and code interoperability if you want test this solution.
All the best.
