Regarding Observation 3835760 …
Signal in the middle is 41168 ATHENOXAT 1
Thank you for your effort.
Yes, the signal may be CANYVAL-C 2U.
Please confirm the signal @geuk-nam
In order to visualize the situation, the below TLE is used!
0 ATHENOXAT1
1 41168U 15077C 21083.55743833 .00003407 00000-0 13909-3 0 9991
2 41168 14.9843 165.0019 0010704 65.8502 331.0432 15.15360322291883
0 CANYVALC2
1 47938U 21022G 21084.77872647 -.00000062 00000-0 00000+0 0 9999
2 47938 97.5641 348.5879 0019147 235.8109 168.9917 15.05584876 515
Just to be clear, both signals are not CANYVAL-C 2U, the one in the middle is 41168 ATHENOXAT, you can also check the other observations of the satellite to see that the pattern matches.
The other at the right is from the IARU declined 46274 ION-MK satellite.
Bellow are the results of ikhnos that show the expected TLE fit(red line) for each satellite and how it follows the received signal:
41168 ATHENOXAT at 437.585:
46274 ION-MK at 437.515:
Okay, Fredy. Thank your comment!
