Hello all,
Regarding Observation 3641325, I seem to not be able to detect any signal from either AIStechSat-3 or UNISAT-6 (other passes over the same station)…
I just set up the station but I’m having problems detecting anything so far. I used to run station 531 but I don’t recall having any problems setting it up so I’m at a loss… here’s my support information, anything helps!
I’ll try tracking other objects but I think the problem is on my side, there were quasi-simultaneous observations of AIStechSat-3 that caught it well.
-------[ copy here ]------------
“versions”: {
“satnogs-client”: “1.4”,
“satnogs-client-ansible”: “202012231828”,
“satnogs-flowgraphs”: “1.3-1”,
“gr-satnogs”: “2.2.0.0-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.2.0-2”,
“satnogs-config”: “0.11”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2021-02-16T08:07:16.768988+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “5.10.11-v7l+”,
“version”: “#1399 SMP Thu Jan 28 12:09:48 GMT 2021”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 4013195264,
“available”: 3720728576,
“percent”: 7.3,
“used”: 148750336,
“free”: 3443478528,
“active”: 144613376,
“inactive”: 356659200,
“buffers”: 28622848,
“cached”: 392343552,
“shared”: 8888320,
“slab”: 38658048
“disk”: {
“total”: 31078248448,
“used”: 3763621888,
“free”: 25997496320,
“percent”: 12.6
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_log_level”: “INFO”,
“satnogs_station_elev”: “55”,
“satnogs_station_id”: “2047”,
“satnogs_station_lat”: “59.350”,
“satnogs_station_lon”: “18.072”,
“satnogs_waterfall_max_value”: “-30”,
“satnogs_waterfall_min_value”: “-120”,
“sentry_enabled”: true
------------[ copy end ]--------
