Observation 3409716: FIREBIRD 4 (40378)
Regarding Observation 3409716
Any reason it marked failed? It started to happen after the client update yesterday.
Logs:
– Logs begin at Sun 2021-01-03 15:43:09 UTC. –
Jan 03 17:51:51 kiosk satnogs-client[4673]: [INFO] Opening Generic RTL2832U OEM :: 00000001…
Jan 03 17:51:51 kiosk satnogs-client[4673]: Found Rafael Micro R820T tuner
Jan 03 17:51:52 kiosk satnogs-client[4673]: [R82XX] PLL not locked!
Jan 03 17:51:52 kiosk satnogs-client[4673]: [INFO] Using format CF32.
Jan 03 17:51:55 kiosk satnogs-client[4673]: Allocating 15 zero-copy buffers
Jan 03 17:58:59 kiosk satnogs-client[4673]: OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOFreq: 437250000 Bias: 0
Jan 03 17:58:59 kiosk satnogs-client[4673]: Found 1 device(s):
Jan 03 17:58:59 kiosk satnogs-client[4673]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Jan 03 17:58:59 kiosk satnogs-client[4673]: Using device 0: Generic RTL2832U OEM
Jan 03 17:58:59 kiosk satnogs-client[4673]: Found Rafael Micro R820T tuner
Jan 03 18:46:32 kiosk satnogs-client[4673]: Freq: 437220000 Bias: 1
Jan 03 18:46:32 kiosk satnogs-client[4673]: Found 1 device(s):
Jan 03 18:46:32 kiosk satnogs-client[4673]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Jan 03 18:46:32 kiosk satnogs-client[4673]: Using device 0: Generic RTL2832U OEM
Jan 03 18:46:32 kiosk satnogs-client[4673]: Found Rafael Micro R820T tuner
Jan 03 18:46:38 kiosk satnogs-client[4673]: Found Rafael Micro R820T tuner
Jan 03 18:46:38 kiosk satnogs-client[4673]: [INFO] Opening Generic RTL2832U OEM :: 00000001…
Jan 03 18:46:39 kiosk satnogs-client[4673]: [R82XX] PLL not locked!
Jan 03 18:46:39 kiosk satnogs-client[4673]: [INFO] Using format CF32.
Jan 03 18:46:41 kiosk satnogs-client[4673]: Allocating 15 zero-copy buffers
Jan 03 18:56:34 kiosk satnogs-client[4673]: OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOsOFreq: 437220000 Bias: 0
Jan 03 18:56:34 kiosk satnogs-client[4673]: Found 1 device(s):
Jan 03 18:56:34 kiosk satnogs-client[4673]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Jan 03 18:56:34 kiosk satnogs-client[4673]: Using device 0: Generic RTL2832U OEM
Jan 03 18:56:34 kiosk satnogs-client[4673]: Found Rafael Micro R820T tuner
