Regarding Observation 3198670 …
With new wideband antenna and RTL sdr:
nice! more details on the antenna?
You can find theory on documents:
I’ve construct antenna with 100 Mhz to 2 Ghz bandwidth, antenna compliment awaits the installation of balun.
The advantage of this antenna is the reduction of interference from terrestrial origins and the possibility with several sdr of beam forming (next step).
Diameter 127 cm about
