Regarding Observation 3056285 …
Hi all, I’ve done a few observations and all of them have had no signals. I’m very new to this so any help would be greatly appreciated.
The sat is definitely still transmitting, from numerous other observations, e.g.: https://network.satnogs.org/observations/3056131/
What antenna is your station using? 70cm satellites are quite difficult to receive without a preamp and a decent antenna - an omni vertical won’t really cut it.
Maybe try one of the stronger UHF sats like FalconSat-3. If you can’t hear that, then you need to upgrade your antenna setup.
I’m using a telescopic Nooelec RaTLSnake M6 v2 antenna.
Alright, thanks for the advice! I’ll keep trying for one of the stronger satellites.
