Regarding Observation 2822251 …
For what it’s worth - this observation from a moxon (turnstyle) antenna with mast amp (minikits eme173 2m) has a minicircuits splitter (ZESC-2-11, 10e6 to 2e9) to share the antenna for satnogs rtl-sdr with a usrp b205mini - this decoded the pass with the usrp - probably redundant sox convert (500 → 288 → 96 KSps) :
record usrp in gqrx at 500e3 samples per second - native format for gqrx is floating complex
$ sox -ef -b32 -r500e3 -c2 gqrx_20200911_132754_137100000_500000_fc.raw -es -b16 -r288e3 m2.wav
~/meteorM2/09112020T0925$ sox -r 288k -c 2 -b 16 -e s m2.wav -t wav meteor_a.wav rate 96k
~/meteorM2/09112020T0925$ sox meteor_a.wav meteor.wav gain -n
~/src/meteor_demod/src/meteor_demod -o meteor.qpsk meteor.wav
looks like a good constellation for most of the pass
~/src/meteor_decoder/medet meteor.qpsk meteor -cd
reading onboard time ok
lots of packets
Total: 70.907028
Processing: 4.680912
Correlation: 11.135599
Viterbi: 50.696815
ECC: 4.283154
Remainder: 0.110550
Packets: 3494 / 4354
Elapsed time: 00:07:04.744
~/src/meteor_decoder/medet meteor.dec meteor_122 -r 65 -g 65 -b 64 -d
Total: 4.430375
Processing: 4.393320
Correlation: 0.000000
Viterbi: 0.000000
ECC: 0.000000
Remainder: 0.037055
Packets: 3494 / 3494
17662006 Sep 11 09:51 meteor_122.bmp
Only one big dropout in the middle, and a small one in the top half - rest is continuous
