Regarding Observation 24540 decoded with direwolf:
[0.2] KM6LYW>SXUTWU,RS0ISS*:`0T.l#@[/`":!}Craig Lamparter via space!_$<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 66
dest SXUTWU 0 c/r=0 res=3 last=0
source KM6LYW 0 c/r=1 res=3 last=0
digi 1 RS0ISS 0 h=1 res=3 last=1
000: a6 b0 aa a8 ae aa 60 96 9a 6c 98 b2 ae e0 a4 a6 ......`..l......
010: 60 92 a6 a6 e1 03 f0 60 30 54 2e 6c 23 40 5b 2f `......`0T.l#@[/
020: 60 22 3a 21 7d 43 72 61 69 67 20 4c 61 6d 70 61 `":!}Craig Lampa
030: 72 74 65 72 20 76 69 61 20 73 70 61 63 65 21 5f rter via space!_
040: 24 0d $.
Audio input level is too high. Reduce so most stations are around 50.
[0.2] WD9EWK>APK004,RS0ISS*::K7TAB-7 :Hi! DM09 in NV {0<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 53
dest APK004 0 c/r=0 res=3 last=0
source WD9EWK 0 c/r=1 res=3 last=0
000: 82 a0 96 60 60 68 60 ae 88 72 8a ae 96 e0 a4 a6 ...``h`..r......
010: 60 92 a6 a6 e1 03 f0 3a 4b 37 54 41 42 2d 37 20 `......:K7TAB-7
020: 20 3a 48 69 21 20 44 4d 30 39 20 69 6e 20 4e 56 :Hi! DM09 in NV
030: 20 20 7b 30 0d {0.
[0.2] WD9EWK>S9SQXS,RS0ISS*:'/L|l <0x1c>S\>"C^}TH-D74 5W & dual-band Elk @ Reno NV ^<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 75
dest S9SQXS 0 c/r=0 res=3 last=0
000: a6 72 a6 a2 b0 a6 60 ae 88 72 8a ae 96 e0 a4 a6 .r....`..r......
010: 60 92 a6 a6 e1 03 f0 27 2f 4c 7c 6c 20 1c 53 5c `......'/L|l .S\
020: 3e 22 43 5e 7d 54 48 2d 44 37 34 20 35 57 20 26 >"C^}TH-D74 5W &
030: 20 64 75 61 6c 2d 62 61 6e 64 20 45 6c 6b 20 40 dual-band Elk @
040: 20 52 65 6e 6f 20 4e 56 20 5e 0d Reno NV ^.
[0.2] KB6IGK>APK004,RS0ISS*::KM6LYW :Hi de DM09 NV QSL? {0<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 56
source KB6IGK 0 c/r=1 res=3 last=0
000: 82 a0 96 60 60 68 60 96 84 6c 92 8e 96 e0 a4 a6 ...``h`..l......
010: 60 92 a6 a6 e1 03 f0 3a 4b 4d 36 4c 59 57 20 20 `......:KM6LYW
020: 20 3a 48 69 20 64 65 20 44 4d 30 39 20 4e 56 20 :Hi de DM09 NV
030: 51 53 4c 3f 20 7b 30 0d QSL? {0.
[0.2] KB6IGK>APK004,RS0ISS*::WD9EWK :Hi de DM09 NV QSL? {1<0x0d>
010: 60 92 a6 a6 e1 03 f0 3a 57 44 39 45 57 4b 20 20 `......:WD9EWK
030: 51 53 4c 3f 20 7b 31 0d QSL? {1.
[0.2] WD9EWK>APK004,RS0ISS*::KB6IGK :ack1<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 39
010: 60 92 a6 a6 e1 03 f0 3a 4b 42 36 49 47 4b 20 20 `......:KB6IGK
020: 20 3a 61 63 6b 31 0d :ack1.
[0.4] WD9EWK>APK004,RS0ISS*::KB6IGK :ack1<0x0d>
[0.2] KB6IGK>APK004,RS0ISS*::WD9EWK :TNX 73!{2<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 44
020: 20 3a 54 4e 58 20 37 33 21 7b 32 0d :TNX 73!{2.
[0.2] WD9EWK>APK004,RS0ISS*::KB6IGK :ack2<0x0d>
020: 20 3a 61 63 6b 32 0d :ack2.
