Observation 2081230: XW-2F (40910)
Regarding Observation 2081230
Do you think this is local interference or the signal coming through?
At about 100s, I think you can see some CW right in the middle of the waterfall.
I’m not sure what that stuff is at the beginning of the pass (it looks to be “straight” and thus doppler corrected - but I’ve never seen a signal like that from the XWs…).
–Roy
K3RLD
[edit] On second look, I think that stuff at the bottom does have a slight slant to it. Looks like DMR, maybe?
Thanks! I definitely see the CW, I think you are right about a close in DMR transmission.
