Hi Steven,
Regarding Observation 2002499 …
I am glad to see you plan the passes of PSAT-2. I see you have yagi antenna for UHF, do you use full pointing (az/el) and LNA at the antenna? As the signal looks quite weak even at high pass. Is there a possibility to get IQ data of the passes at your station as the signal of the sat is frequency drifting and following it manually greatly enhances detection possibility.
Best regards
Tomas OK2PNQ builder and control station of PSAT-2
