Hi Eduard,
Regarding Observation 1996383 …
I am glad to see you planning the passes of our sat, just please plan the passes, when the sat is in the Sun, as it shut down the transmission, when it enters the eclipse and start when entering into Sun again or after 30 minutes of eclipse.
To your station, do you use some LNA at the UHF antenna?
Best regards
Tomas OK2PNQ, builder control station of PSAT-2
I see no evidence of PSAT-2 in this observation, yet it is vetted as “good”.
@eddyosp I’ve vetted the observation as bad as @K3RLD noted there isn’t any sign from the satellite. In case you haven’t checked, please take a look at the vetting guide.
@ok2pnq Thank for the info, unfortunately currently on scheduling functionality there isn’t a way to tell if the satellite is in sun light or not, so it is difficult to schedule the satellite only when in sunlight. However there is this open issue for implementing a functionality like that.
