Yes, there is clearly no signal here, so the observation should be marked as bad.
The data packet that was decoded is definitely a false decode. This is due to the increased sensitivity of the newer FSK demod flowgraph, which seems to be a bit too sensitive, and is resulting in more false decodes. @surligas has a change in progress which tweaks this a bit to reduce false decodes.
False decodes, plus the observation being marked ‘good’ on receipt of any packet is an ongoing problem, particularly with CW and APT observations, but more recently with FSK observations too.
Unfortunately there aren’t that many recent observations, and it looks like there are lot of observations there incorrectly vetted as good. I’ve had a look through a few and re-vetted some, but in pretty much all of them i’ve just seen local noise.
