Observation 1941836: AENEAS (38760)
Regarding Observation 1941836 …OK so somewhere it decoded a packet. I listen to the audio but did no hear anything or saw anything on the waterfall
The AX.25 decoder in the latest updates appears to be getting a lot of false-positives. I’ve seen similar on many other observations.
Apparently there has been a fix, however I don’t know when it will make it through to all users. @surligas?
Yes, on master there is “improvement” for the false positive frames. However, this comes with a slightly less sensitivity. The issue originates mainly from the small CRC of the AX.25.
