Regarding Observation 1919615 …
Hi, this looks like an “okay” signal to me. Would it be possible to decode the audio file recorder through any type of decoder ? Does PSK31 look like this indeed ?
Thanks,
Ben
Thanks,
Ben
Yes, that is the PSK beacon (the thing that looks like a smeared fingerprint). Looks like nobody was using the transponder as the signal would be much longer if it was in use. I’ve never tried running a recording through FLDigi… Not sure if the demodulated audio is correct, though (trying to download an ogg right now but download is slow).
–Roy
K3RLD
Yep, I just downloaded an ogg file from a good observation and FLDigi will decode it just fine!!
[edit] aside from any drift, that is.
