Regarding Observation 1886587 …
Why is this marked successful, if there is no audio ?
Heh, this observation seems to meet the requirements for both “good” and “failed”. I guess either would be acceptable.
I, personally, would leave it as “good”, as the the satellite can be observed in the waterfall. This essentially means that the observation at least has value.
–Roy
K3RLD
It was automatically vetted as good due to the false positive data file that was uploaded.
However there is visible signal from ISS in the waterfall, so regardless if there is audio or not should be vetted as good.
