Observation 1885831: SARAL (39086)
Regarding Observation 1885831
Hi, being a bit of a noob on Satnogs I am getting the point to vet the observations. The rtl device (in my case) is doppler corrected for the given satellite so all the lines from -10 kHz to +10 kHz are terrestrial signals. In this observation indeed there is a signal in the middle of the waterfall, should I assume the data like signal shifting from left to right to be a digital terrestrial signal ?
Thanks,
Ben - PE2BZ from the Netherlands
Spot on Ben :slight_smile:
