Regarding Observation 1737767 (among other observations), it seems Argus-02’s transmission frequency may have shifter down 10-20kHz. We are unsure as to why, but we have seen Argus-02’s pattern on this slightly lower frequency consistently. Would it be possible to add a transmitter on this frequency to see if. Argus-02 is better captured?
For context, Argus-02 transmits telemetry every 45s, which fits the pattern.
I can not say for sure that the visible signal is from Argus-02, it seems that it doesn’t fit any TLE of the deployment, event if I drift the frequency.
To be honest I haven’t checked all the observations until now but I’m on it. We will need more observations with signals and from more stations to be sure.
I’ve seen this suggestion, however I haven’t managed to check the observations for confirming it and accept the change.
It will be very helpful if you can list here all the observations that show signal of Argus-02 that matches the interval of 45sec and are at -10KHz - -20KHz from the announced frequency.
The signal at right-center is 43466 - 1KUNS-PF and the CW at left is 32785 - CUTE-1.7+APD II
The signal at the right is AZTECHSAT-1 and the faint signal at left is a terrestrial one.
The signal at the right is AZTECHSAT-1, the signal on the left is either noise or terrestrial signal. For example in this observation the noise/terrestrial signal is more visible https://network.satnogs.org/observations/1751567/.
Again as the previous observation from this station the signal at the right is AZTECHSAT-1 and the one faint at left is a terrestrial one.
At the right is AZTECHSAT-1 and at the left/center the noise/terrestrial signal, again in station #6 as in the previous. Here is more obvious that the noise/signal follows the terrestrial noise line starting from -10KHz at the bottom.
I can not see any signal
Again signal at the right is AZTECHSAT-1
Again the noise/terrestrial signal on #6
Signal at right is AZTECHSAT-1. The other horizontal lines are noise, you can see something similar in the other observations of this station, like this one.
