Regarding Observation 1710915 …
I’m always missing a waterfall on this sat. Any specific isssue I should be looking at ?
73’s Martin 9V1RM
73’s Martin 9V1RM
Exact same thing happens to me, just with Pratham everytime. Also note, it should be rated as “failed” not “bad” if it is blank, I think.
cc’ing @surligas on that since he might be able to provide more info on why this CW always fails.
indeed @jebba is right, this is a “failed” one (I went ahead and re-rated it)
Might have to do with the CW transmitter having a baud of 35.0 in DB? Could be messing up gnuradio flowgraph.
Thank you - I will look at the other pass as re-rate them.
73’s Martin
gr-satnogs v1.5.1
supports WPM less than 30, that’s why it fails. > v2
will supports up to 100.0.
