Regarding Observation 1637 …
Decoder gr-satellites GOMX-1.
2017-03-02 21:07:27
Timestamp: 2017-03-02 16:09:19
Flags: 0x79
Beacon A:
OBC:
Boot count: 2046
Board temp 1: 19.0ºC
Board temp 2: 21.0ºC
Panel temps: [0.0, 22.0, 22.0, 10.0, 16.75, 28.5]ºC
COM:
Bytes corrected by RS: 0
RX packets: 0
RX errors: 0
TX packets: 299
Last temp A: 22ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.41V
Last TX current: 842mA
Boot count: 4635
EPS:
Boost converter voltages: [2.579, 2.568, 0.0]V
Battery voltage: 8.26V
Current out: (4, 2, 141, 40, 5, 0)mA
Current in: (235, 271, 0)mA
Boost converter current: 100mA
Battery current: 176mA
Temperature sensors: (22, 23, 21, 22, 20, 20)ºC
Output status: 0x1c
EPS reboots: 0
WDT I2C reboots: 179
WDT GND reboots: 339
Boot cause: 4
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 4
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 17ºC
Boot count: 915
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0)
ADCS:
Tumble rate: (-1.43951416015625, -0.7396697998046875, -0.06744384765625)
Tumble norm: (4.249481678009033, 0.8668508529663086)
Magnetometer: (-351.75531005859375, 141.41188049316406, -138.72445678710938)
Status: 0x3
Torquer duty: (85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (89, 9, 8, 5, 5, 17, 0, 0)
2017-03-02 21:08:38
Timestamp: 2017-03-02 16:10:29
Flags: 0x79
Beacon A:
OBC:
Boot count: 2046
Board temp 1: 20.0ºC
Board temp 2: 22.0ºC
Panel temps: [0.0, 16.25, 17.5, 9.75, 14.5, 22.0]ºC
COM:
RX packets: 0
RX errors: 0
TX packets: 306
Last temp A: 22ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.42V
Boot count: 4635
EPS:
Boost converter voltages: [4.984, 4.972, 0.0]V
Battery voltage: 8.317V
Current out: (52, 2, 173, 33, 5, 0)mA
Current in: (344, 132, 0)mA
Boost converter current: 230mA
Battery current: 127mA
Temperature sensors: (22, 23, 22, 22, 20, 20)ºC
Output status: 0x1d
EPS reboots: 0
Boot cause: 4
Battery mode: invalid mode 3
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0
HUB:
Temp: 17ºC
Boot count: 915
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0)
ADCS:
Tumble rate: (-4.400482177734375, -2.5302886962890625, 1.1925506591796875)
Tumble norm: (4.236509323120117, 0.8647953271865845)
Magnetometer: (-377.2604064941406, 148.15167236328125, -132.01242065429688)
Status: 0x3
ADS state: 0x22
ACS state: 0x22
Sun sensor: (5, 6, 215, 205, 6, 0, 16, 0)
