Would this be classed as a good observation?
It’s very faint but there appears to be a broken signal running along the centre of the waterfall
I can see FOX-1B 120 and 280 secondes on the waterfall, It’s good but increase gain or change antenna of your station for better result.
Example of modulation for FOX-1B :
https://network.satnogs.org/observations/1492465/
https://wiki.satnogs.org/SatNOGS_Client_Ansible#SatNOGS_Client_Setup
https://wiki.satnogs.org/Antennas
Thanks Michel, I appreciate the feedback and info.
I only just got my setup running last night with a slim jim aerial that’s still indoors, so a way to go yet!
That hint won’t help you with your question, but others by helping out you!
Please keep the “Regarding observation […]” link that is automatically added at each post, so others can simply “click” on the observation’s link to find it.
All the best!
This is the observation that @mervinator is talking about: https://network.satnogs.org/observations/1497508/
I’m pretty confident that the signal between 250 and 300s is FOX-1B.
Am I doing something wrong with my replies? I’m just hitting the reply icon which I assumed would keep the observation link alive
The first post seems to be modified…
