Do we have any simple tweaks/settings to make the morse decode more reliable? I dont know a lot of morse, so as it the decode is far better than I can do.
ChatGPT decode:
1 HELLO THIS IS KKS-1
2 8-52-11 MINAMI-SENJYU ARAKAWA-KU
TOKYO-TO JAPAN
3 TOKYO METROPOLITAN COLLEGE OF
INDUSTRIAL TECHNOLOGY
[partially obscured]
… KKS-1 PROJECT
I am working on a ‘plugin’ for Satnogs that uses deepcw (https://deepcw.cc/) to decode CW transmissions from the IQ and audio ZMQ sockets. The author of deepcw claims a marked improvement over other tools, and my experience supports this (GitHub - e04/deepcw-engine · GitHub). At the moment I have been working with ARICA-2 and KOSEN-1 and have seen a marked improvement over the inbuilt decoder, which seems to love to decode ‘E’s (’.') and terminate packets prematurely. Increasing the word size limit helps a bit but that E problem still fills any available space. Setting the confidence threshold higher doesn’t give any benefit in my experience.
I’ll share it in it’s own thread once I have tackled some aspects of it that I need to think through with regard to optimisation/heuristic processing/benchmarking, with the goal of ideally having it accurate enough that it can do MOST of the process of getting CW transmissions into online telemetry dashboards with maybe a final check from the observer to make sure we aren’t polluting the data.
A preview; here is the decode of the .ogg file from the observation you shared earlier kc1oca, I think you’ll be impressed In the meantime, playing the files in the browser through the deepcw web app is a lot easlier and more powerful than fldigi et. al.
T OMETROPOLITAN COA GEOFIIHU4RIALTECHNM JQ1YYY 52Q1YYY 5JQ1YYY 5JQ1YYY 5JQ1T 610/01/24 0571270 0 610/ 01/24 057P 1HELLO THIS IHKDST1 1HELLO THIS IS SBT1 1HELLO THIS IS KKS6 28BT52BT11 MINAMIBTSENJYU ARAKAW EBTKU TOKYOBTTO JAPAN F 3TOKYO METROPOLITAN COLDEGE OFINDUSTRIAL TECHNOL AGY 3 TOKYE K TSBT1 PROJECT TOKYO METROPOLITAN COLLEGE OFINSTTRIAL TECHNM 5LK1YYY 5JQ1YYI 5JQ1YYY 5JQ1YYY 5JQ1T 610/01/24 05 1890 0 61 0/ 2/24 0591N HVDT SSNN
reynico, thankyou for sharing that contribution of yours, somehow I missed it. Do you have any side-by-side performance data? I will install it at my station pronto.
Hi, one simple cross-check that helps with exactly this: when a decoder struggles with single dots, that is usually a threshold problem, so it is risky to trust one decode on its own. Download the observation .ogg and run it through a second decoder to compare. The beacon repeats its callsign (JQ1YYY) and the “HELLO THIS IS KKS-1” part several times, so you can check whether both decoders agree on those known parts before trusting the rest.
Full disclosure, I run a free browser-based Morse audio decoder that decodes an audio file right in the page, nothing to install. I use it for second opinions on SatNOGS audio. Where the two decodes agree on the repeats, the copy is probably solid; where they differ, that is the spot to listen to by ear.
