Observation 14530694: TISAT 1 (36799)
Regarding Observation 14530694 …Hello everyone,
I have successfully received the CW telemetry from TISAT 1 (Observation #14530694).
While I have confirmed the signal, I am currently looking for information regarding the frame structure or the decoding process for its telemetry data. If anyone has resources or documentation on how to interpret these CW packets, I would greatly appreciate your guidance.
Best regards, YUKIO NAKAMURA
中村さん
On UHF the CW beacon structure is HI HI HI TISAT x where x stands for the temperature of the transmitter.
x                          F    B   K   R   H   N   T   E   I   S   A   D   M   U   5   L
Temperature in °C  -10  -5   0 +5  10 15 20 25 30 35 40 45  50  55 60 65
On VHF it’s vvv HB9DE TISAT1 x
よろしく
ダニエル
Dear Daniel,
Vielen Dank! Thank you very much for your kind and detailed explanation. I truly appreciate you sharing the telemetry decoding rule for TISAT 1.
It is fascinating to learn that the last character indicates the temperature of the transmitter. Now, I can interpret my observation data clearly thanks to your help.
Herzliche Grüße (Warm regards), YUKIO NAKAMURA JP7DVX
