Observation 14156729: Unknown 2 - T16 (98345)
Regarding Observation 14156729
i am seeing the recent observation for unknown 2, I see the waterfall shows peaks at 100kHz deviation (very faint, but visible). instead of seeing 2 peaks, 4 peaks are visible, can this be concluded as a false observation (maybe some other signal from the background?)??
Also, the TLE used is for very long and some observation is picked, it will be great if you could help me to read that observation and help me identify the unknown sat from the remain unclaimed objects which are as follows.
OBJECT Y
OBJECT E
OBJECT K
OBJECT AT
OBJECT A
OBJECT Z
OBJECT BD
OBJECT L
OBJECT B and Object BT
