Regarding Observation 139311 …ZACUBE successfully decoded!
Happy that your update worked!
This is different groundstation I am still googling to update gr-stanogs. My linux skills are still frustrating low
Oh, that should be pretty easy:
$ sudo satnogs-setup
- Choose “Update”
- Choose “Apply”
- Choose “Back”
“Apply” might take a while! Watch out you never hit the “Reset Configuration” entry
Thanks Patrick. I have done that plenty times and it work great. I think for a start the gr-satnogs was never installed I am writing a new image and will then follow installation again!
73s
hm, what?
Without gr-satnogs you would get no results at all
I was under the impression if you install the client that it will install everything necessary. Assumption is the mother of al … Reading community and wiki is so important
I’m not sure I get you right!
It does install gr-satnogs, at least if you use the “Update” method mentioned above.
OK so the plan is to install it according to this wiki
https://wiki.satnogs.org/Raspberry_Pi_3
using this image
then do the rpi configure password, time etc
then run
sudo satnogs-setup
and see what happens
Yes, exactly!
To get a bit more security you should add a new user with sudo permission and remove the default Pi user.
At least: change the passwort!
Ok I changed the password with still pi as user, lets see
so the satnogs client will install this by default?
Yes, if you have satnogs-client already running, please update to the newest release, using
$ sudo satnogs-client
- Choose “Update”
- Choose “Apply”
- Choose “Back”
I have done this plenty times on old version, let see with new version. Busy installing
That normally appears if you deinstall gr-satnogs, eg to install a local build of it. But with updating through satnogs-setup the binary will be installed. Have you followed the instructions for the Pi image installation exactly?
There seems to be missing something from the pip-installation also. This should normally bei included in the Pi image, afair.
I think it would be better to continue this discussion in a normal thread - is it possible to move this by an Admin?
Not sure if it is or not – it might just be easier to start a new thread and link to the relevant posts here.
One other thing: if any of the wiki is out-of-date or incomplete, please feel free to create an account and update it – that’ll make it better for everyone.
