Regarding Observation 138516 …
I did two things: QFH outside the roof. And: Pulled out the metal shield of the USB cable. I hope it helps…
When will the next NOAA come over EU?
What does pulling out the shield do?
I’m speaking about my setup only: It produces less tihs.
Compare the two waterfall pictures:
https://network.satnogs.org/observations/134734/
and
https://network.satnogs.org/observations/138516/
As Mythbusters says: Don’t try this at home.
Hm maybe passing the cable thru an RF choke like on the USB Printer cables might help? Could also just be something like a ground loop somewhere causing it.
This might help, too. Yes.
