Observation 13739974: ORBCOMM FM118 (41183)
Regarding Observation 13739974
Can someone guide me on when I should mark it as bad, since the waterfall shows a line but no data is received?
hello friend, welcome to satnogs
mark it as bad when no signal in waterfall, and mark as good when you seen the signal on waterfall even no data decoded.
for your obs that line is not signal from orbcomm. the signal should seen like this
based on your metadata obs
i have advice to your station to look and change the value of this variable from null to 48 (adjust RF Gain value for your SDR hardware):
SATNOGS_RF_GAIN=48.0
good luck!
Hello Bali!
Thank you so much for the warm welcome
and advice!
I have updated SATNOGS_RF_GAIN=48.0
and will monitor the next observations.
Also understood the rating rule,
will rate properly from now on.
Looking forward to contributing good
observations from Mumbai, India! :india:
73, Sunil
Station #4763 Mumbai-RTL-1
Hello Bali!
After setting RF_GAIN=48.0
First decoded data received from SilverSat!
AP2XGW SHAE decoded successfully!
Thank you for the advice!
73, Sunil”
cool!
That ‘S’ means the battery is at full charge.
