Observation 13713563: NOAA 19 (33591)
Regarding Observation 13713563 … whats the failure reason?
Hi @lanzo and welcome in the community!
It is marked as failed as the station didn’t upload any artifacts (observation results like waterfall/audio/data). This may caused by satnogs-client crashing or something else.
The best way to debug this is to follow the troubleshooting guide and check the logs to see if there is an error.
Thank you :slight_smile:
hi lanzo, please check your station config
it should be:
look at satnogs_antenna variable, it should be:
SATNOGS_ANTENNA=RX
Thanks bali:) i did that and finally got my first signal. Appreciate it.
DId by any chance you also check the gain ? SatNOGS Network - Observation 13725717 it’s automatically vetted as good cause the system thinks there was some kind of data available, but I notice your gain is (was ?) not set if I read the metadata right ?
Oh yeah, just set it. Thanks!
Looks much better
To disappoint you a bit, the NOAA’s are no longer transmitting APT in 137 MHz for half a year now.
Oh my god😭 it’s my first time using satnogs, what do u suggest me to do? Best option atp?
There are no APT satellites left. If you need to receive weather satellite images the best bet would be to check if / how you can decode the Meteor satellites, for which I think 2 are still operational in 137 MHz
ugh none are giving me any signals. could u check my observations? sorry i’m new and its for a project. thanks btw
Looking at the meta data, I am surprised it is working at all
soapy-rx-device: "RTLSDR",
samp-rate-rx: "2.048e+06",
This should be
soapy-rx-device: "driver=rtlsdr",
samp-rate-rx: "2.048e6",
thanks boss, trying again:) also which transmiter and satellite would u recommend for my 137MHz
Run this query and you will see successful METEOR M2-4 observations.
These including frequency and mode.
for what project my friends ?
I’m an electrical engineering student and taking a communication course
