Not a valid pass what what could cause this signal it? Using an Eggbeater ED-432/RK70CM antenna for the first time they had here and have to admit I am underwhelmed by it. Just getting poorer that normal results and odd stuff like this.
Howdy, I looked at a few of your observations and most are OK, it seems frequencies around 450 upwards capture that noise seen in your observation above. This could be a rogue Power Supply or laptop / pc or other electrical devices causing the issue. Are you able to run sdr software and investigate with a small yagi, run laptop on batteries or move the sdr away from potential issues?
