Observation 13018443: Foresail-1p (98467)
Regarding Observation 13018443
It’s considered “failed” but the waterfall and audio is there?
ussualy its false failed, caused when network is bottleneck, so late post the obs result
That’s not true, when watefall, audio file or data are uploaded even after a late post the status changes from fail to unknown.
The case here is that observation duration is 11min and 20sec but the audio duration is 4min and 13sec. When the audio file duration has more than one minute difference with the scheduled duration the observation automatically marked as failed.
answer my failed obs too
thank you!
May I ask why the sample rate for SDR is choosen to be such a strange value instead of 2.048 ?
i just test it, follow other station that give good result. but look not too good result on my station
Hello,
Because of this topic : Observation 12326506: WEIRD WATERFALL - #11 by PE0SAT
I was told to reduce the rate to avoid a recuring issue with wrong SDR output.
aha. i try follow sample rate @auk groundstation @pe2bz . look at this obs. very good result
Please bear in mind however that I recently put the min/max dB manually to try to see a the signals better. Waterfall is not automatic on this one.
