Observation 12763379: VZLUSAT-2 (51085)
Regarding Observation 12763379
running satnogs-client docker version 2.1. but no data decode uploaded. grsat is work. decode ogg file manually is work. try to make kiss output using gr_satellites , also work.
satnogs_client_1 | INFO satnogsclient.observer.observer Begin observation 12763379 …
satnogs_client_1 | INFO satnogsclient.radio.grsat Starting gr_satellites for observation 12763379 at 48000 sps
satnogs_client_1 | INFO satnogsclient.observer.observer Start gnuradio thread.
satnogs_client_1 | rig_check_rig_caps: p1=0x7f6f000640, p2=0x7f6f006bc0, rig_model=0x7f6f000640, macro_name=0x7f6f006bc0
satnogs_client_1 | initrigs4_dummy: _init called
satnogs_client_1 | rig_init: rig_model=Hamlib NET rigctl
satnogs_client_1 | rig_init: rx_range_list1 is empty, using rx_range_list2
satnogs_client_1 | rig_init: rig does not have tx_range!!
satnogs_client_1 | netrigctl_init version 20230106.0
satnogs_client_1 | Found Rafael Micro R820T tuner
satnogs_client_1 | Found Rafael Micro R828D tuner
satnogs_client_1 | RTL-SDR Blog V4 Detected
satnogs_client_1 | [INFO] Opening Generic RTL2832U OEM :: 1004365…
satnogs_client_1 | [INFO] Using format CF32.
satnogs_client_1 | Allocating 15 zero-copy buffers
satnogs_client_1 | INFO satnogsclient.scheduler.tasks Upload of waterfall image for observation 12755287 successful.
satnogs_client_1 | CCSDS RS Decoder1 :debug: decoded RS block with 5 error symbols
satnogs_client_1 | crc_async :debug: Wrong CRC
satnogs_client_1 | CCSDS RS Decoder1 :debug: decoded RS block with 1 error symbols
satnogs_client_1 | CCSDS RS Decoder1 :debug: decoded RS block with 0 error symbols
satnogs_client_1 | CCSDS RS Decoder1 :debug: dropping RS block due to error symbols
satnogs_client_1 | netrigctl_close: done
satnogs_client_1 | INFO satnogsclient.radio.grsat Stopped gr_satellites
satnogs_client_1 | INFO satnogsclient.radio.grsat Processing kiss file
satnogs_client_1 | INFO satnogsclient.radio.grsat Total frames: 0
satnogs_client_1 | INFO satnogsclient.observer.observer Observation 12763379 finished.
satnogs_client_1 | INFO satnogsclient.observer.observer Executing post-observation script.
satnogs_client_1 | /iq/iq_12763379_48000.raw : 47.16% ( 88.8 MiB => 41.9 MiB, /iq/iq_12763379_48000.raw.zst)
satnogs_client_1 | INFO satnogsclient.observer.observer Artifacts upload for observation 12763379 successful.
satnogs_client_1 | INFO satnogsclient.scheduler.tasks Upload of audio recording for observation 12763379 successful.
satnogs_client_1 | INFO satnogsclient.scheduler.tasks Upload of waterfall image for observation 12763379 successful.
grsat_12763379.txt (16.0 KB)
obs-12763379.txt (11.8 KB)
