Observation 11546350: ArcticSat-1 (61762)
Regarding Observation 11546350
well… I’m new with gr_satellites
I got this from this observation.
Is it correct?
Is it TLM?
📡 Running gr_satellites with satellite 'ARCTICSAT-1'...
log :warning: `pdu_to_tagged_stream` has moved to gr-pdu and will be removed from gr-blocks soon. Please update to use pdu.pdu_to_tagged_stream()
((transmitter . 9k6 USP FSK downlink) (rs_errors . 0) (iterations . -1))
pdu length =        105 bytes
pdu vector contents =
0000: a4 64 82 9c 8c 40 60 a4 a6 6e 68 a6 40 63 00 f0
0010: 46 42 02 00 01 00 19 00 08 00 ff 71 22 08 d4 0e
0020: a4 c2 19 68 86 d2 01 00 80 25 00 00 26 00 20 1f
0030: 01 21 ed 04 00 01 00 30 00 5c 12 d1 13 26 10 00
0040: 00 35 00 56 00 20 00 00 00 2f 00 00 00 00 00 00
0050: 00 9c 00 96 00 8f 00 c1 00 00 40 00 00 2c 1f 02
0060: d3 01 00 51 cc 96 5a 5c 04
Yes it is, replay of you audio.
gr_satellites ARCTICSAT-1.yml --wavfile 11546350.ogg --samp_rate 48e3
alternative_names:
  - RS74S
norad: 61762
  &tlm AX25 telemetry:
    telemetry: ax25
  2k4 USP FSK downlink:
    frequency: 435.890e+6
    modulation: FSK
    baudrate: 2400
    deviation: 600
    framing: USP
    - *tlm
  4k8 USP FSK downlink:
    modulation: FSK
    baudrate: 4800
    deviation: 1200
    framing: USP
    - *tlm
  9k6 USP FSK downlink:
    modulation: FSK
    baudrate: 9600
    deviation: 2400
    framing: USP
    - *tlm
-> Packet from 9k6 USP FSK downlink
Container:
    header = Container:
        addresses = ListContainer:
            Container:
                callsign = u'R2ANF' (total 5)
                ssid = Container:
                    ch = False
                    ssid = 0
                    extension = False
            Container:
                callsign = u'RS74S' (total 5)
                ssid = Container:
                    ch = False
                    ssid = 1
                    extension = True
        control = 0x00
        pid = 0xF0
    info = b'FB\x02\x00\x01\x00\x19\x00\x08\x00\xffq"\x08\xd4\x0e\xa4\xc2\x19h\x86\xd2\x01\x00\x80%\x00\x00&\x00 \x1f\x01!\xed\x04\x00\x01\x000\x00\\\x12\xd1\x13&\x10\x00\x005\x00V\x00 \x00\x00\x00/\x00\x00\x00\x00\x00\x00\x00\x9c\x00\x96\x00\x8f\x00\xc1\x00\x00@\x00\x00,\x1f\x02\xd3\x01\x00Q\xcc\x96Z\\\x04' (total 89)
gr_satellites ARCTICSAT-1.yml --wavfile 11546350.ogg --samp_rate 48e3 --hexdump
Using the SPUTNIX Telemetry Viewer
question: I try to run your same command. but it gives me
Are you using a different version?
Could not open SatYAML file:
[Errno 2] No such file or directory: 'ARCTICSAT-1.yml'
I shared the ARCTICSAT-1.yml content in the previous post, create the file with the content shared.
This is my first time hearing of this software. Could you please give a little tutorial or briefing on how to use it or understand the interface?
Like all AGWPE client implementations you need a soundmodem that support this client server protocol. The soundmodem version from UZ7HO all support this option and is enabled by default.
Some steps:
Run the UZ7HO soundmodem for the specific satellite/mode and check settings → devices to see if the AWPE Server port is set and activated.
Now you can run the SPUTNIX Telemetry Viewer and click connect.
All audio received by the soudmodem and that is successfully decoded will be forwarded via the AGWPE link and converted to telemetry information.
MS TLM decoding block diagram.
Another quick check is via notblackmagic.com
Just copy the first 16 bytes (the first row)
(Destination Callsign - Source Callsign)
and paste it as shown in the screenshot below.
Thank you very much
