Regarding Observation 1125 …
Decoder gr-satellites GOMX-1.
Frames 28 .
- MESSAGE DEBUG PRINT PDU VERBOSE *
pdu_length = 258
contents =
0000: 1c 96 f8 7d ef 8e c0 c2 90 c3 aa f7 2b 7e ad eb
0010: b7 12 ce 5a 97 72 cc 1f a2 ee 3e 4c 10 ac 88 94
0020: cd ea b1 fe 94 23 81 22 1a f7 79 1c 59 27 58 07
0030: 6d c7 8d 75 32 0c 85 6a 45 78 5c 75 21 aa 11 2b
0040: 9b 7a 63 de 20 3e 02 68 35 c3 f2 31 b3 15 b6 9e
0050: dd 64 39 7d 5d e0 30 dc 8a ea f8 3d 43 d3 3f 53
0060: 37 aa 6a fb 08 72 04 d0 6b 85 e4 71 64 9d 6d 3d
0070: ba 36 71 d4 bb ee 61 95 15 f9 f0 50 87 8c 44 a6
0080: 6f 55 8f f4 80 ec 09 a0 d7 0b c8 e2 c9 3a da 7b
0090: 74 6c e5 a9 77 dc c3 2a 2b f3 e0 b0 0c 61 8b b0
00a0: de ab 1f e9 3e 7d f2 41 11 54 85 c5 ad 29 7c f6
00b0: a8 57 ae 35 d0 af a1 11 94 33 d2 3d 5d 6e 0f 87
00c0: 7e 55 bb 0e 00 72 8c 83 5c 6d 89 8b 24 a9 c3 ed
00d0: d1 91 b4 a1 92 4d 08 97 af cf 80 a9 cb ae 16 31
00e0: ec 33 66 40 53 0f 39 76 49 fb 48 34 26 29 e0 fe
00f0: d5 e3 23 e1 f1 3c a7 1e 75 f1 93 55 50 ea 0d 5c
0100: 85 e4
Timestamp: 2017-02-10 12:33:26
Flags: 0x79
Beacon A:
OBC:
Boot count: 2029
Board temp 1: 19.0ºC
Board temp 2: 21.0ºC
Panel temps: [0.0, 3.75, 11.25, 20.25, 17.5, 23.25]ºC -
COM:
Bytes corrected by RS: 0
RX packets: 0
RX errors: 0
TX packets: 1086
Last temp A: 22ºC
Last temp B: 22ºC
Last RSSI: 0dBm
Last RF error: 0Hz
Last battery voltage: 8.4V
Last TX current: 842mA
Boot count: 4544 -
EPS:
Boost converter voltages: [7.415, 7.439, 0.006]V
Battery voltage: 8.289V
Current out: (73, 2, 175, 35, 5, 0)mA
Current in: (1, 9, 347)mA
Boost converter current: 0mA
Battery current: 127mA
Temperature sensors: (23, 23, 22, 22, 21, 21)ºC
Output status: 0x1d
EPS reboots: 0
WDT I2C reboots: 173
WDT GND reboots: 328
Boot cause: 4
Latchups: (0, 0, 0, 0, 0, 0)
Battery mode: invalid mode 3 -
GATOSS:
Average FPS 5min: 0
Average FPS 1min: 0
Average FPS 10sec: 0
Plane count: 0
Frame count: 0
Last ICAO: 0x0
Last timestamp: 1970-01-01 00:00:00
Last latitude: 0.0
Last longitude: 0.0
Last altitude: 0ft
CRC corrected: 0
Boot count: 0
Boot cause: 0 -
HUB:
Temp: 17ºC
Boot count: 889
Reset cause: 2
Switch status: 0xfc
Burn tries: (0, 0) -
ADCS:
Tumble rate: (1.295928955078125, -0.76202392578125, 0.8624267578125)
Tumble norm: (4.449878215789795, 0.586536705493927)
Magnetometer: (-424.1523132324219, 223.11373901367188, -131.51898193359375)
Status: 0x3
Torquer duty: (-85.0, 85.0, 85.0)
ADS state: 0x22
ACS state: 0x22
Sun sensor: (4, 77, 62, 4, 63, 0, 0, 2)
