Regarding Observation 1102894 …How do you get the data values to decode? Does it decode automatically when the signal is strong enough or is there a setting that I need to adjust?
Great reception! Yes, the DUV decoder is built into the client (or at least bundled with it), so it will decode Fox frames automatically if you have a good S/N ratio. Nice work.
–Roy
K3RLD
