Observation 1087: GOMX 1 (39430)
Regarding Observation 1087 …
Decoder gr-satellites GOMX-1
Frames 19.
Timestamp: 2017-02-09 11:51:51
Flags: 0x79
Beacon A:
  • OBC:
    Boot count: 2028
    Board temp 1: 19.0ºC
    Board temp 2: 21.0ºC
    Panel temps: [0.0, 8.0, 19.0, 12.75, 8.75, 19.0]ºC
  • COM:
    Bytes corrected by RS: 0
    RX packets: 6
    RX errors: 6
    TX packets: 1904
    Last temp A: 22ºC
    Last temp B: 22ºC
    Last RSSI: 0dBm
    Last RF error: 0Hz
    Last battery voltage: 8.42V
    Last TX current: 842mA
    Boot count: 4539
  • EPS:
    Boost converter voltages: [2.719, 2.706, 0.0]V
    Battery voltage: 8.307V
    Current out: (50, 2, 166, 38, 5, 0)mA
    Current in: (362, 285, 0)mA
    Boost converter current: 153mA
    Battery current: 127mA
    Temperature sensors: (22, 22, 21, 21, 20, 20)ºC
    Output status: 0x1d
    EPS reboots: 0
    WDT I2C reboots: 173
    WDT GND reboots: 327
    Boot cause: 4
    Latchups: (0, 0, 0, 0, 0, 0)
    Battery mode: invalid mode 4
  • GATOSS:
    Average FPS 5min: 0
    Average FPS 1min: 0
    Average FPS 10sec: 0
    Plane count: 0
    Frame count: 0
    Last ICAO: 0x0
    Last timestamp: 1970-01-01 00:00:00
    Last latitude: 0.0
    Last longitude: 0.0
    Last altitude: 0ft
    CRC corrected: 0
    Boot count: 0
    Boot cause: 0
  • HUB:
    Temp: 17ºC
    Boot count: 888
    Reset cause: 3
    Switch status: 0xfc
    Burn tries: (1, 1)
  • ADCS:
    Tumble rate: (3.0706787109375, 1.6873931884765625, 2.4538421630859375)
    Tumble norm: (4.273968696594238, 0.5650778412818909)
    Magnetometer: (-410.0120849609375, 199.97425842285156, -124.61746978759766)
    Status: 0x3
    Torquer duty: (-85.0, -85.0, 85.0)
    ADS state: 0x22
    ACS state: 0x22
    Sun sensor: (5, 5, 117, 203, 5, 0, 17, 0)
