Regarding Observation 1052618, has this been marked as good because of the two weak signals in the center, at around 200s and 320s.
Is that the expected PAINANI-1 signal? Just to understand, since I saw it in other passes even weaker.
Yes this should be, however we don’t have any decoded data in order to be 100% sure. However given that they are in a straight line increase the chances.
