Maybe Drew @ko4ma can help in these contacts?
SilverSat
2025-12-03 14:11:46z shne
2025-12-03 14:14:49z shns
2025-12-03 14:17:54z shnt
All the character definitions for the SilverSat beacon is at Beacon Operations · silver-sat/systems Wiki · GitHub
In general, the beacon is showing:
I recommend we continue SilverSat-specific discussion over on Observation 12858633: SilverSat (98538) - #6 by ve6kdx. I’ll continue to track both discussions.
CU-ALPHA had been talking about deploying the sail (and therefore, the beacon) possibly on 3-Dec or 4-Dec, but there has not been any update for a day or so.
Anyone have an update? Thanks!
Update SilverSat TLE
SilverSat
1 98538U 98067A 25337.66000688 .00009722 00000-0 29997-3 0 09
2 98538 51.6307 187.4386 0003628 192.4733 280.2333 15.49981636 05
Silvsersat is currently the only one being received over Europe.
Thanks for the SilverSat TLE update, Jan!
This early after deployment, is it fair to say that the last TLE provided for CU-ALPHA if probably not correct since it does not align w/ the ISS nor SilverSat?
I used the previous Silvsersat TLE as a templates, so that should explain that mystery.
I’m going to use the SilverSat TLE for the other satellites deployed with it as they would be better than ISS ones. Given the number of the satellites and the timing, I expect to have soon TLEs from space-track.
So for the rest:
RHOK-SAT
1 99932U 98067A 25337.66000688 .00009722 00000-0 29997-3 0 08
2 99932 51.6307 187.4386 0003628 192.4733 280.2333 15.49981636 04
ContentCube
1 98468U 98067A 25337.66000688 .00009722 00000-0 29997-3 0 01
2 98468 51.6307 187.4386 0003628 192.4733 280.2333 15.49981636 07
CU-Alpha
1 98462U 98067A 25337.66000688 .00009722 00000-0 29997-3 0 05
2 98462 51.6307 187.4386 0003628 192.4733 280.2333 15.49981636 01
SilverSat https://network.satnogs.org/observations/12859050/ SHNT
Had hopes of a high-elevation pass this evening; was scanning for any sign of CU-Alpha and/or Foras Promineo.
Unfortunately, right after AOS, the entire spectrum around 437.400 was overwhelmed w/ noise from an unknown source.
Finally was able to capture an I/Q from the 62k5 LoRa downlink from CU-ALPHA.
Reversed LoRa parameters and found differences w/ values provided. After adjusting my RX devices, clean decode on replay!
Will try live decodes on next pass, but elevation less than I’d like.
Please ignore timestamp - this first decode was a replay:
Catalog numbers (66909 1998-067XS to 66912 1998-067XY) and associated TLEs have been published on Celestrak. None of the satellites’ names have been associated yet.
Download TLEs from Celestrak’s Active Satellites TLE set at https://celestrak.org/NORAD/elements/gp.php?GROUP=active&FORMAT=tle or the new TLEs set http://www.celestrak.org/NORAD/elements/tle-new.txt
P.S. Prior incorrect catnums were corrected.
Please take my last post w/ a grain of salt.
The admin of tinyGS has indicated that this is NOT likely a downlink from CU-Alpha. Will update when I know more.
SilverSat’s ground station in Maryland has also seen K4KDR’s interference. We suspect it might be a United States government radar or another transmitter listed at https://www.ntia.gov/files/ntia/publications/compendium/0420.00-0450.00_01MAR14.pdf
The interference is either 15 MHz wide or overloading the RTL-SDR.
Painful and please accept my apologies!
I wanted to hurry & post my findings before the next pass over North America, but thanks to some quick peer review by the tinyGS admin, this is apparently a 62k5 downlink from a different satellite. (decode from another ground station below)
Final note on my mistake to any SatNogs admins - you may wish to purge the decode that got uploaded to the production database (after I’d done some experimental decodes in the DEV database).
Fixed, thank you for the update.
SilverSat
2025-12-06 10:07:05z shne
2025-12-06 10:10:10z shne
2025-12-06 10:13:13z shnt
Below is how I’ve set the NORAD IDs we will follow for the satellites the next days, except SilverSat that is transmitting, all the other are semi-randomly selected based on deployment time:
| Satellite Identifier | Name | Temporary NORAD ID | Followed NORAD ID |
| NLSP-2262-9359-6303-6169 | CU-ALPHA | 98462 | 66908 |
| UYJQ-4751-9718-1378-8291 | DUPLEX | 98463 | 66906 |
| ILJU-3352-7058-1614-3713 | FORAS PROMINEO | 98465 | 66911 |
| OTRZ-8981-5796-9802-9606 | CONTENTCUBE | 98468 | 66912 |
| JMIF-0517-5295-9753-0215 | SILVERSAT | 98538 | 66909 |
| NTJV-2293-0787-8038-8343 | EAGLESAT-2 | 98912 | 66910 |
| GDGL-8515-2553-1728-8249 | RHOK-SAT | 99932 | 66907 |
NOTE: For SilverSat, OBJCT XU(66908) is also a good candidate, so we will need to wait before finalize any identification.
Why 66906 but not 66909 ?
