Hi Guys
I just got a Yaesu G-5500 Az-El rotor and built a Arduino SimpleSat Rotor Controller. This rotator works very well when i use Antenna control test in gpredict and I can see debug data in the rotctld window on linux. I can also engage the rotator using the rotctl client.
The problem is that gpredict does not begin to track when any satelliates are in view. I have selected Autotrack and watched the rotcld terminal window, Gpredict does not even send data to engage the tracking… What could I be doing wrong. I have set my elevations in the rotator interface and all.
I am running Ubuntu 20.0.4 with Gpredict version 2.3-33-gca42d22-1.
rotctld -vvvvvv -m 601 -r /dev/ttyACM0
I have read the manual and looked at the logs on gpredict and all I see is:
2021/11/19 10:09:16|1|rot_ctrl_timeout_cb: MAX_ERROR_COUNT (5) reached. Disengaging device!
but no tcp data is being sent to rot_ctl.
Any help would be really appreaciated
73’s
