NOOB station - first install - SDR setup fail
Hi All,
first timer, RPi3b+, RTLSDRv 3
going throught the install on the pi.
Get this error:
TASK [satnogs-radio : Unload SDR modules] ***************************************************************************************************************************************************************************************************
failed: [localhost] (item=dvb_usb_rtl28xxu) => {“ansible_loop_var”: “item”, “changed”: false, “item”: “dvb_usb_rtl28xxu”, “msg”: “modprobe: ERROR: …/libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file ‘/lib/modules/4.14.52-v7+/modules.dep.bin’\n”, “name”: “dvb_usb_rtl28xxu”, “params”: “”, “rc”: 1, “state”: “absent”, “stderr”: “modprobe: ERROR: …/libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file ‘/lib/modules/4.14.52-v7+/modules.dep.bin’\n”, “stderr_lines”: [“modprobe: ERROR: …/libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file ‘/lib/modules/4.14.52-v7+/modules.dep.bin’”], “stdout”: “”, “stdout_lines”: []}
Stuck.
Wade
Can you please specify how you are doing the install? Are you using the ready-made SD card images?
entirely my error, using an old version. Using new image and off it went, station 1025
