No waterfall uploaded. I tried running journalctl command and here`s the error I got.
Here`s the output from Advanced support:
“versions”: {
“satnogs-client”: “1.6”,
“satnogs-client-ansible”: “202109022142”,
“gr-satnogs”: “2.3.1.1-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14satnogs2”,
“satnogs-config”: “0.12”
“state”: {
“is-applied”: false,
“pending-tags”: null
“system”: {
“date”: “2021-09-16T18:33:02.387271+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “5.10.60-v7l+”,
“version”: “#1449 SMP Wed Aug 25 15:00:44 BST 2021”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 8282419200,
“available”: 7932190720,
“percent”: 4.2,
“used”: 106745856,
“free”: 7880126464,
“active”: 70230016,
“inactive”: 276099072,
“buffers”: 21102592,
“cached”: 274444288,
“shared”: 8826880,
“slab”: 31318016
“disk”: {
“total”: 31078248448,
“used”: 2830237696,
“free”: 26930880512,
“percent”: 9.5
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_rf_gain”: “32.8”,
“satnogs_station_elev”: “435”,
“satnogs_station_id”: “2391”,
“satnogs_station_lat”: “47.430”,
“satnogs_station_lon”: “8.562”
Solved after basic settings was applied. (Apply and update the basic settings.)
