Some updates:
- Bobcat-1 is back for good, after some experiments at 38k4 is now transmitting at 1k2 baud rate.
- SPOC continues beaconing, we will need some newer TLE, probably generate some tomorrow.
- Unfortunately no news for the rest of the satellites. There is a chance Neutron-1 to transmit at 435.275, so we have scheduled some more observations to verify that. However, we discovered that AIST-2D is transmitting at 435.270MHz, something that we need to add in DB.
- While trying to generate TLE for Bobcat-1, we noticed some unknown signal on the observations above Europe. After a lot of speculation, we managed to find out that it is AISTECHSAT-2 of AISTECHSPACE.
AISTECHSAT-2 was declined coordination by IARU as it was a non-amateur mission:
However they ignored the regulations and proceed with transmitting at 436.730 MHz, and we discovered now that they also transmit at 436.600 MHz.
