Newbie Help Required Please
Good Afternoon.
So I just got this installed on the RasPi followed the instructions to the letter but I get this . . .
And not a lot else.
Anyone got any pointers ?
Allen
pi@raspberrypi:/var/lib/satnogs/local/lib $ journalctl -u satnogs-client.service
– Logs begin at Tue 2019-03-19 18:24:21 UTC, end at Tue 2019-03-19 18:25:02 UTC. –
Mar 19 18:24:31 raspberrypi systemd[1]: Started SatNOGS client.
Mar 19 18:24:31 raspberrypi satnogs-client[529]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.
Mar 19 18:24:32 raspberrypi satnogs-client[529]: Traceback (most recent call last):
Mar 19 18:24:32 raspberrypi satnogs-client[529]: File “/var/lib/satnogs/bin/satnogs-client”, line 6, in
Mar 19 18:24:32 raspberrypi satnogs-client[529]: from satnogsclient.main import main
Mar 19 18:24:32 raspberrypi satnogs-client[529]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnog
Mar 19 18:24:32 raspberrypi satnogs-client[529]: from validators.url import url
Mar 19 18:24:32 raspberrypi satnogs-client[529]: ImportError: cannot import name url
Mar 19 18:24:32 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=exited, status=1/FAILURE
Mar 19 18:24:32 raspberrypi systemd[1]: satnogs-client.service: Unit entered failed state.
Mar 19 18:24:32 raspberrypi systemd[1]: satnogs-client.service: Failed with result ‘exit-code’.
Mar 19 18:24:32 raspberrypi systemd[1]: satnogs-client.service: Service hold-off time over, scheduling restart.
Mar 19 18:24:32 raspberrypi systemd[1]: Stopped SatNOGS client.
I think I may have solved this - give me 5 mins
didn’t work, going for a third image install and see if that fixes it
Can you provide a link to those instructions? Maybe there is something wrong where you are looking?
Also please copy paste the settings you set in “satnogs-setup” BUT hide first your API key.
You can find them all by choosing “Show” in the initial menu of “satnogs-setup”.
