Hello everybody,
two days ago i set up my satnogs station, # 2136. Everything went fine, station went online immediately after installation process, i scheduled several passes that came out ok. So, really a good start, considering that I’ve never used a Raspberry Pi before and I have no knowledge of Linux environment.
Today i wanted to change the RF gain to test with other values, in the satnogs-setup main window, after changing the gain value, i mistakenly hit the ‘Update’ instead of the ‘Apply’ selection. Realising the mistake, I quit (ctrl-C) the ‘Update’ session and did the ‘Apply’. From the dashboard I soon realised the station went offline after that.
So, i did a full ‘Update’, that took a long while, during the process i was asked to confirm few step and i did, at the end i performed the ‘Apply’ again (plus rebooting), but nothing happened. Station is offine.
If I try to ‘Update’ again, nothing is done because I’m told that ‘the repository didn’t change’ and i’m back at the satnogs-setup main window.
If I run the scheduler I get the following situation:
pi@raspberrypi:~ $ journalctl -f -u satnogs-client.service
– Logs begin at Sat 2021-04-03 20:33:22 UTC. –
Apr 03 20:38:34 raspberrypi satnogs-client[333]: satnogsclient.scheduler.tasks - ERROR - 401 Client Error: Unauthorized for url: https://network.satnogs.org/api/jobs/?ground_station=2136&lat=44.988234&lon=9.124798&alt=177
Honestly, i’m really frustrated because I don’t know what to do more. If anyone can help me.
Thanks
Maurizio iu2jwg
