Hi, all I have installed satnogs on a raspberry pi 3B using a RTL-SDR v3 dongle I am having a problem with it not getting any date no audio no waterfall here is the log
pi@raspberrypi:~ $ journalctl -f -u satnogs-client.service
-- Logs begin at Tue 2020-03-31 15:07:09 UTC. --
Mar 31 15:20:23 raspberrypi systemd[1]: Started SatNOGS client.
Mar 31 15:23:42 raspberrypi systemd[1]: Stopping SatNOGS client...
Mar 31 15:23:42 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=killed, status=15/TERM
Mar 31 15:23:42 raspberrypi systemd[1]: satnogs-client.service: Succeeded.
Mar 31 15:23:42 raspberrypi systemd[1]: Stopped SatNOGS client.
Mar 31 15:23:42 raspberrypi systemd[1]: Started SatNOGS client.
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: rot_init called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: dummy: _init called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: rot_register (1)
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: rot_register (2)
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: dummy_rot_init called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: rot_open called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: dummy_rot_open called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: rot_get_position called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: dummy_rot_get_position called
Mar 31 15:43:21 raspberrypi satnogs-client[6398]: rot_set_position called
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: [INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-2
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: Found Rafael Micro R820T tuner
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: Traceback (most recent call last):
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: File "/usr/bin/satnogs_fsk_ax25.py", line 491, in <module>
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: main()
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: File "/usr/bin/satnogs_fsk_ax25.py", line 476, in main
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: File "/usr/bin/satnogs_fsk_ax25.py", line 92, in __init__
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: tune_args, settings, samp_rate_rx, "fc32")
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: File "/usr/lib/python3/dist-packages/soapy/soapy_swig.py", line 166, in make
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mar 31 15:43:27 raspberrypi satnogs-client[6398]: RuntimeError: soapy::source: Unsupported sample rate. Rate must be in the range [8000.000000, 8000.000000] [16000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.000000] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 96000.000000]
Mar 31 15:43:30 raspberrypi satnogs-client[6398]: satnogsclient.observer.observer - ERROR - No waterfall data file found
This is the settings that I have set up
any help would be grateful.
