manu
#1
Hello to the group
I just joined you hoping to count on your help if ever …
I finished building the rotator and started the control circuit.
I hope to do some tests next week.
I will have the antenna to build to join the network I think in September.
Sorry for my English Google!!
IMG_20190815_143055|281x499
Regards!
Manu
manu
#2
good evening everyone
I finished assembling the rotator and the control board. Everything works perfectly and I can order it from the FTDI console and card.
I would like now to be able to order it in RS232, I followed the instructions in the wiki unfortunately the communication does not work.
Can you help me? What is the port configuration on PC 19200 8/1 / n?
Should the program be modified?
Regards
Manu
azisi
#3
Hey!
These are the available communications with board according to wiki:
If you want to use RS232 you must use an adapter.
As defined in easycomm3 protocol:
.serial_rate_min = 9600,
.serial_rate_max = 19200,
.serial_data_bits = 8,
.serial_stop_bits = 1,
Also do the pre-flight check and then the trouble shooting.
Normally not.
manu
#4
Thank you for the info.
The link works in RS232 with David Taylor’s wxtrack program.
I can not make it work by sending orders manually but I think it is an error on my part on the syntax (ASCII, Hexa …)
I will not look too much longer, I will realize as soon as possible the configuration of the Raspberry.
For the moment I have “grilled” an engine interface by plugging it upside down.:fâché:fâché:
Manu
