I’m trying to setup Satnogs under Debian 11 (Bullseye) on a little i5 portable computer. Trying to determine the correct installation process is a bit confusing.
The wiki for installing on Linux desktop looks deprecated, but there is also a satnogs-client Ansible. I’m assuming this is the preferred method these days? Also, do I need to create a dedicated “satnogs” user or can I just use my account on the machine to run it?
The Ansible method is the way to go although there is a relatively new dockerized container version as well.
A basic username of your choice should be used during the installation process. That is, don’t create a ‘satnogs’ user, it will be created automatically.
Thanks, Scott. Looks like I got things configured and connected. It doesn’t look like the “sysctl status satnogs-client” command work, also I don’t see any logs in /var/log/ related to satnogs. I need to spend some time learning how things work here it seems. I’ve got a rotator project in the works too.
-John
