Hi will like to introduce myself my name is Elpidoforos Anastasiou and i am an I.T teacher us parts of our school project this year we are hoping to build our own satnogs based on a 5.5 meter satellite dish ,our goal is to fully be motorized . i will post some pictures soon . thanks
[/quote]
Hi @ELPIS – welcome to SatNOGS! I very much look forward to seeing how your build progresses. And as a Canadian myself, I approve of the purchase from the Canadian seller.
OH thanks i am sure we will make it ,just had a few questions on how many rpm should i have for the 360 rotation ?
and yes canadia products are the best :>:>
Look forward to the progress
Hm – if I understand correctly, you’re asking how fast the antenna needs to rotate? If that’s correct, I’m not sure I know the answer…I think it would depend on the orbit of the satellite being tracked. Sorry I don’t have a better answer, but I have not built a rotator yet.
If I have not understood your question correctly, maybe try re-stating it and someone else may be able to help out here.
yes basically how fast it needs to rotate correct question . I think between 1 to 2 rpm will be ok .OH by the way the project will be completed by students i am a teacher so i created a group of 4 kids 14-15 years old all of the are exited :>
OK got my answer yesterday :> between 2 and 6 rpms
HI one question are we going to need to buy a different The DC motor controller is Dual MC33926 Motor Driver Carrier for our system ?
i see that support up 24 volts but how about the amps ?
this are the specs of our motor
Hey!!
Also you can check here the analysis for satnogs rotator about the angular speed.
If in stall torque the “Absorbed power (W): 60” in 24V means that the stall current is 2.5A.
According to DC motor driver specification, there is no problem driving the DC motor.
Ok thanks :)
can i ask if anyone know if we can order the controler v2 completed reason i am asking is because it will save a lot of time and we will be able to focus on incorporating the satnogs controller to our custom rotator desing
Hello
Hello much help needed we found a company that basically want to sponsor us huge satellite dish for our project
we need specs frequency span,dish diameter, rate of turn(for tracking purposes)
Cam someone help us out :))
