I receive errors when running “sudo apt update” when attempting to download from the opensuse.org repository…see the photo of the screen
The satnogs-setup also fails to run.
Suggestions?
Suggestions?
If you are using a Raspberry Pi (as it seems you are), I recommend you use the image that is known to work.
https://wiki.satnogs.org/Raspberry_Pi_3
Does this help?
I am running a RPi4 with a fresh install of the download from the indicated web site. Thanks…John
Are you connected to a network (wifi or ethernet) and logged into that network?
@nu8m
Yesterday there was an issue with the openSUSE download server which is used by SatNOGS for hosting the gr-satnogs package. The issue was fixed later yesterday, so it should work again.
Yes…it now works and I am able to continue to the first observation…Thanks
